blackout82
- Joined
- Feb 21, 2011
- Posts
- 27
- Reaction score
- 0
is there a way to replace my high pressure power steering hose without taking everything else off?
some of this advice is spot on and some not so.5 minute job it is NOT! At least on 4wd models like my 97. It took me several hours. Getting the fittings loose is doable without removing the shroud under and behind the radiator but reoving it definitely helps but the high pressure hose is a combo of steel with tight curves and swaged hose and is pretty unyielding and getting it to thread is the hard part with the minimal clearances. It is made much worse by the independent front suspension which makes it more crowded than the 1970's-80s models with a solid axle. That job was indeed a 5 minute job. It i would be easier on a lift as well. I am a pretty skilled mechanic but my lift was broken and it was an unpleasant job getting the fittings together without cross threading and with all the oil everywhere from the leak. This is a job I would farm out to a shop were I to have to do it again. The steel curves were not perfect either and I had to make some slight bends in the steel line to get the fittings aligned perfectly.
