Peep these tie rod angles
wafflecakes13
Still trying to diagnose my horrible handling. What do ya'll think about the more severe angle? It looks almost broken. Seems weird that the front is almost the same height on both sides of the truck but that much differen20170716_170914.jpeg ce of angle. Any thoughts?20170716_170935.jpeg
slow4dr
Looks like the drag link isn't centered. Which would mean the pitman arm isn't aligned properly on the steering box splines.
slow4dr
Although, at second glance. It appears that the CV is angles just as bad in the 2nd pic. If the CV angle is way different on that side as well.......then your $hit is all fubar
wafflecakes13
wafflecakes13
Yes, the cv angle is way worse on that side also. Unfortunately I've already lowered the keys as much as I can. Front sides are almost at identical height but different angles, I don't get it. Unless the torsion bars are more worn on one side...
slow4dr
Torsion adjustments wouldn't effect this with ride height equal on each side. It's almost like the whole drivetrain is offset to one side.
The only other explanation I can think of is there is a shit ton more weight on one side so even though the fenders are at equal height the chassis is not flat/parallel to the ground.
rickyrick63
