Passenger side dash metallic tapping noise
Matahoe
Grand Rapids, Michigan
I've got a noise directly in front of the passenger dash more near the firewall. It sounds like a dangling wire hitting a panel of shear metal. It's quite loud when driving seems to only make noise going over bumps. I have ruled out suspension and wheel brakes as a cause. I put my ear up in that area of the dash closest to the firewall. It sounds like maybe the antenna or some other heavy gauge wire may be loose.
M1Gunner
Gainesville, Fl
In my opinion, the Heat shield on your passenger side catalytic converter is a good place to start looking. The welds begin to come lose over time and sounds horrible.
Sometimes you can raise the idle of the engine to approx 1500-2000 rpm and you'll get it to rattle which will be a dead give away that it's a cat's heat shield.
Matahoe
Matahoe
I took it back to the body shop. They found the front quarter panel cracked in a few places.
MyCleftNut
