Fleetgeo
- Joined
- Feb 14, 2017
- Posts
- 125
- Reaction score
- 46
I keep getting a randomness misfire code for P0300 code I replaced spark plug wires ,plugs , fuel filter , fuel pump , and the code is still there
I didn't clean my mass air flow yet but it does work properly I disconnected it and felt the idle change so that should mean it's working I cleaned the throttle body and hooked up a On2 snap on solus scanner and checked all the sensors no problems and it has no vacuum leaked I hooked a gauge up its more of a intermittent problem
What's do you guys recommend cleaning the maf with I'll give it a shot it's been intermittent one week it'll drive like a dream next week it'll be idling really bad til the point where if I stop at a light it'll idle so bad it'll shut off then I turn it back on and it turns on perfect then in less then a minute or so it'll idle bad again
