kbuskill
So I recently (2-3months ago) replaced my oil pump with the high volume/high pressure pump from Mellings and it completely eliminated the lifter ticking that I was experiencing from time to time.
Before the new pump I would have 40psi at idle with a cold engine and around 20-25psi at idle with a hot engine.
Now with the new pump I have a little over 60psi cold idle and a little under 60psi hot idle and about 65psi while cruising.
The "problem" I have now is I keep getting a CEL and the code is
P0521 (Engine Oil Pressure Sensor/Switch Circuit Range/Performance)
Now some background. When I first did the oil pump, along with a bunch of other work, I pulled the oil pressure sensor and removed the screen filter underneath it and reinstalled the sensor.
I never had any problems or CEL for oil pressure before and didn't have the P0521 pop up for a couple weeks after installing the new pump.
When it did pop up I checked it and cleared the code and took a 1000 mile trip each way plus the local driving around for the week we were out of town then got home and drove around locally for another couple weeks before the code reappeared.
I checked/cleared it again and it reappeared again within a day and I did the same thing again and it reappeared again within a day.
So my question is...
Does anyone know what PSI range the ECU is looking for as "normal pressure"???
I just hate to go to all the trouble of removing the intake to change the sensor only to find out there is nothing wrong with the sensor that is on the truck and the ECU is just setting the code because the oil pressure is "too high".
Also if it is "too high" I am thinking of reinstalling a new screen filter to try and keep the sensor from "seeing" so much pressure, although I doubt it will help much, I have read others posting that removing the screen showed an improvement in oil pressure on their gauge although I am not certain how clogged their screen may have been.
My oil pressure gauge works flawlessly which is another reason I am doubting that there is anything actually wrong with the current sensor.
Any and all help would be appreciated. If no one can give me a definitive answer on the range the ECU is looking for then the only thing I can think to do is call Black Bear and see if they know or can look into the ECU's programming for the answer and if it is out of range then my only option may be to get a tune and have them change the parameters on the oil pressure range to a higher setting.
