Oil pan gasket
Discussion in 'Engine & Drivetrain' started by Posiburner, May 14, 2018.
  1. Posiburner
    Posiburner TYF Newbie
    Jun 9, 2015
    Name:
    Sean
    My 04 Tahoe 4wd needs an oil pan gasket.My question is that my truck has a 6 inch suspension lift on it.Does anyone know if that makes the job easier?
  2. Bigbertha78
    Bigbertha78 Full Access Member
    137
    21
    Apr 4, 2015
    Name:
    Chuck
    Only thing you will have to worry about is the cross member under the pan and the front diff. If they are low enough, you will not have to remove or lower them down.
  3. Rocket Man
    Rocket Man Super Elite Member Supporting Member
    6,963
    8,308
    Name:
    Yeah- you probably don't need to put it on jackstands.
  4. Posiburner
    Jun 9, 2015
    Name:
    Sean
    Lol! Yeah I get that but was just wondering how much clearance I would need to get the pan clear of the crank shaft
  5. David Smith
    David Smith Full Access Member
    335
    208
    May 2, 2017
    Savannah, GA
    Name:
    David
    Clearing the crankshaft is not the issue. You will more than likely still have to remove the crossmember and lower the front diff to change the gasket.
  6. Rocket Man
    6,963
    8,308
    Name:
    You actually might be OK without dropping the front diff, I had to drop mine about 3" for the pan to clear the crank. Only way to tell for sure is try. The crossmember will still need to come off I believe. Just have to get under there and do it.
  7. xjsc16x
    xjsc16x Member
    77
    Aug 25, 2017
    Name:
    Justin
    If your lift is one of those that relocates the whole IFS down, then you might not need o move the diff. I just did this on my stock 02 tahoe and I barely got the pan out having unbolted the diff and pulled it down some.
    Easiest way to tell is to just look at it. If there's not at least 6" of room between the pan and diff then you gotta drop it.
    -Jusin
    Rocket Man likes this.
  8. Posiburner
    Jun 9, 2015
    Name:
    Sean
    Ok thanks I will take another look.
Share This Page
