No rear heat
SnowDrifter
Washington. The desert side not the Starbucks side
'05 Tahoe LT, auto climate control
Haven't used my rear heat since last winter. Went to use it the other day and found it not working
- Both rear heater core lines are warm
- Switching from overhead to feet-heat works
Just trying to figure out what my diagnostic tree here is. Control box? If so, how do I check? Blend door actuator? Again, how do I check? If the plastic bits are seized, what's the best approach to ensure they don't stick again in the future?
Just trying to get all my ducks in a row before I tear into it
Z28TWITCH
That to be honest I cannot answer. I played around with a few things and that was the easiest/least time consuming to do. I guess a lot of tahoes and yukons have modules that are just crap right out of the box and it's a fairly common fix from what I understand.
Icyagent
