New to the forum
mportkiller
I'm new to the forum and I'll be looking for some advice on some of the common problems I'm having. First one...I wired in 25 watt 3.9 ohm resistors on each shock and on the compressor wires. I hooked the battery back up and tried starting it without fuses #2, 54, and 58. Still showing the Service Suspension message. My other issue is the Service Stabilitrac Traction Control message. This goes along with the hard 1st to 2nd shift and flashing CEL. Getting a multiple cylinder misfire code and a C0561 ABS Ram Rom Module code.
Other than that, here's my Suburban.29fff050d3b8d1dab52388846e330e38.jpg1c1a288b2ec8089961faa69f842e4cdc.jpge22cc1599b16b5d062fe0dfae7906602.jpg
Sent from my SM-N920V using Tapatalk
kbuskill
NE. FL.
The service stabilitrac and ABS code are both caused by your multiple misfire code. The ECU will disable stabilitrac and ABS by default to make sure that one of those isn't causing your misfires since both of those have the ability to cut power from the engine if they detect a loss of traction.
Figure out what is causing your misfire and fix it and most likely the other two will straighten themselves out.
Good looking rig BTW.... also I like your stickers on the back window... 3% all the way.
22loweryak
