Chevy Venture?Can anyone help me with my Venture? I will post the details if it is allowed.
I have a 03 venture with 286k miles. It has been doing the whole security flashing thing for years. A few months ago it started leaking coolant , couldn't find from where. Last week the radiator started leaking and it over heated. I switched out the radiator. Now it won't start.I'll give it whirl, what's the matter with it?
Yes a 3400. Yes it started after it over heated. Like I said in the OP it will start if I use a jumper on the starter but dies 2 seconds after I remove it.what engine you got in it? a 3400?
did it ever start again after it over heated? possible sized block.
try jumping the starter while it on the car?
most security issues can be cleared up with a security learn, most are key to run for 10 minutes then off for less then ten seconds, and back to run for another 10 minutes, so its key to run for 10 minutes 3 times, the 4 th time it should crank and fire up. you can hook up a battery charger during this if your battery is weak, this is a 1/2 hour of your life your not getting back, make it count.
or you lack a chipped key, then you need a dealer to cut you a new key with the right chip in it. might even need to re program the key.
