Need help with DRL's !
Luis Ramirez
I have an 03 suburban and the daylight running lamps gave out and seem not to work anymore . I tested the fuses and they seem to work . Bulbs were burnt but swapped with new ones and still don't work. Any ideas on how to fix them again? Thanks !
NardDog
I have a similar issue. So i replaced the sockets, used the newer recommended bulb, but now my fuse keeps blowing out. Not sure if i wired the sockets wrong or what. Post back if you figured this out yet.
Check your sockets, they burn up. Also the DRL relay in the under hood fuse box.
firstcaddy
