Need Help with 95 Tahoe
BoB00001
So my buddy gave me his 95 tahoe 4x4 5.7L, cause it needed lots of work and he never recieved a title. Anyways fast forward a couple of months, I replaced throttled body gaskets, fuel pressure regulator, pvc valve, icv, coolant temp sensor, tps, map sensor, rotor, wires, plugs, fuel filter, air filter, battery, starter and did a oil change and timing. It starts but soon as you put it in drive or reverse it stalls out, the idle is rough and its running rich.
I'm out of ideas, short of replacing the O2 sensor or fuel pump. Any help is appreciated alot. Thanks.
BigBee44
