harveje
- Joined
- Dec 24, 2013
- Posts
- 103
- Reaction score
- 6
Good evening,
Been reading thru forum on code and getting different angles on it.
Code sets every week or two and usually will set after an extended 4-6 sec crank time which is unusual, truck usually starts right up. When it happens it will turn over 4-6 sec before deciding to run, usually no sputter or stumbling after it starts.. A quick scan shows intake map 6 psi, commanded evap purge 11.8%, evap system vapor pressure 13.50Pa, barometric press 30 psi,
Truck still has erratic idle and shake that's it's had a long time. Gas cap is tight, and no other coded set or pending. Weird thing is my 04 avalanche has the P0 mass leak code that I'm chasing too....
Go finger
Thanks for the help
Go finger
Thanks for the help
