supergreen
- Joined
- Jan 9, 2012
- Posts
- 3
- Reaction score
- 0
I have a 96 Tahoe, 5.7, 4wd, 100k. The past few weeks it has had a drip of coolant resulting in an area about the size of a paper plate. Does not drip until motor cools off. I took it to local place and they pressure tested it but no leaks. let off pressure and discovered clamp on bottom hose loose enough for seepage when motor not running. Went a few days and leak is back. took it again , kept it overnight and discovered next day clamps on bypass to water pump loose, tightend them and all is well for about 2 days and leak is back. Temp remains normal. Driving me crazy!!! I cannot tell where it is coming from under neath but it collects on harmonic balancer. Any suggestions/help would be much appreciated!
Thank you
Thank you
