Lights and radio not shutting off
Mikey_T49
The Willamette Valley, Oregon
My check airbag light would display about half the time when the car was in use. That stopped but then the dash lights and radio would stay on after the car was shut off and the door was opened. I have to shut them off manually. Any help is appreciated.
J Mac
Newport News, VA
Maybe try disconnecting the battery for a few mins? I've had some weird stuff happen before and that solved it.
On the airbag light...if that starts again...mine was doing that. Ended up being the connection under the driver's seat. If you have power/heated seats, there will be 2 connectors under the seat (at least on mine), the smaller one is tied into the airbag system. I just disconnected that one, put some dielectric grease on pins and reconnected. Haven't had the light come on again in the 3 months since I did that.
GeorgeC
