Larger rotors?
Tractoman
Do the ppv and ssv rigs have larger discs or beefier calipers? If they do could they be put on standard trucks?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
No but there are big brake conversions out there.
Mighty Hd
Florida
Not at all. I have a 2013 Z71 4wd and installed Raybestos PPV rotors and the Hybrid H3 pads. What a hell of an improvement over factory. Tight pedal, zero brake fade; quite impressive. Ordered from Summit for around $375
Zirk
Idaho
Do the PPV rotors offer any benefits over the stock OEM rotors?
Mighty Hd
Florida
Significantly improved cooling abilities, the rotor itself is slightly heavier than the factory unit. It is also Trude to a higher tolerance than a standard rotor. I noticed an immediate difference in the smoothness of the braking
https://www.brakepartsinc.com/raybestos/en-us/products/rotors/police.html
If you use the Raybestos H3 hybrid pads, you absolutely must use the red CRC brake quiet.
I've had these on for a couple thousand miles now and I still stand behind that it is a very significant improvement overstock pads and rotors.
btheboyscout
