I have an interesting issue with my knock sensors tripping my timing.. They set the light off with no other issues over 1/4 of a tank of fuel. When I go under 1/4 a tank I loose massive amounts of power until the sensors trip the timing which leads to a 40 mph top speed. I replaced the knock sensors about 2 years ago and the fuel pump last year (put an AC Delco pump in the original sending unit). The problem is so persistent that I bought a Bluetooth OBD scanner to clear the codes if my fuel gets too low. It also surges while idling with low fuel.
Now for my beliefs..
Is it possible for the pump to be sucking air at low fuel levels causing my hellish conditions but just enough to only make it run bad? I'm certain the performance issues are from the fuel pump
01 Yukon
5.3
320k miles
01 Yukon
5.3
320k miles
