Key In Ignition
Blake Biundo
I have a 2007 Tahoe, I would like to keep the key in the ignition and then just carry around the Remote to lock and unlock the car, but I am worried I will kill my battery. Does leaving the key in the ignition drain the battery?
morriskb
Missouri
I've been doing that for years in my last 5 GM Trucks. When you turn the ignition off, pull the key out around 1/2" to when the dome lights come on. That's your sign that the ignition is no longer seeing your key. Additional confirmation is when you open your door, there won't be any chime reminding you that the key is in the ignition. Just make sure you have access to a spare key in case your remote decides to die on you one day.
Blake Biundo
Blake Biundo
Awesome thank you!
Tttterrrr
