Hydroboost upgrade
Jedi-GT
My 99 2dr yukon is due for a brake changed I was holding off on the hydro boost upgrade.
I wanted to get the parts new from the dealership... few things I need help with:
The model year of the NBS hydroboost
The parts numbers for all the parts needed
Just a note that I need to change everything to be GM later years ... discs, caliber, brake lines, master cylinder, hydroboost etc ALL
Pictures and parts numbers would be deeply appreciate of what the items looks like
Thanks
Mr. Sir.
Phone Man
Long Island NY
I was looking into the same swap soon and did some research on it. Go on ebay and type in hydroboost. Find the seller "just chevy trucks". Their stuff is usually shown with a florecent green backdrop. They have the hydroboost unit from newer trucks with the MC for around $175. Then go to rockauto and get the rest of the parts for the diesel version, they had hydroboost brakes.
The reason for using that truck is because it will have the correct length and shape for the lines to and from the power steering unit (which you should also get) that will properly fit our engine compartment. You will also need a cooler and filter for it.
Juju14
