Hello, Just bought a 2003 Suburban for the wife and family to use on vacations. Found one that runs and drives great but does have a few gremlins hiding inside.
2003 Suburban. Having HVAC controller issue. The fan speed control works ok. the temp selector does not change air temp. only blowing cool air. unable to change air flow from floor to dash to defrost vents. only blows from dash vent. Also the back lights do not light up when headlights are on.
The rear controller on the roof seems to work ok for the bank vents. I can change from cool to heat and change the fan speeds. but those are on a different control panel.
I've googled for a few days on this issue, I've tried pulling the HVAC fuse to reset reset the system a few times with no luck. I pulled and tested all the fuses that listed HVAC or any type of control on them, didnt find anything out of place. I've pulled the controller from the dash, The plugs and wires look ok, dont see any issues with the pins or rear of the controller.
I dont think this is related but the Radio was not getting a switched 12v power to turn on with the key,
thank you for any help. Radio fuse seem to be ok. I ran a jumper from a switched 12v power wire so now the radio works. Looks like the previous owner had a system installed. I found some boot leg wiring for it. Pulled all that junk out and think I've got most of that fixed. Dont think its related to the HVAC issue but thought I would list it in case someone thought it is.
It almost seems that the plug on the right side of the controller, that would control them and vents isnt working or doesnt have power. I'm planing to get a Haynes book on the way home tomorrow so I can trace the wiring for the plug and test with a meter. Hoping some one here might be able to point me in the right direction on where to start looking.
I would be grateful for any help.
