High output alternator needed for amplifiers and subs?
Dilutedpjn
I will be installing 2 1500 watt amplifiers and two 12" subs in my 2016 Tahoe LT. I also have 2 2 Farad capacitors that are going in. Will it be necessary to add a high output alternator to my truck or should I be fine?
Duff87
Chesapeake va
Your going to atleast need to upgrade your oem battery to an agm battery then add a second agm battery.
Dilutedpjn
Dilutedpjn
Is this mandatory or can I get by with a stock setup? Also, without doing what you said, what will the side effects be?
Duff87
Chesapeake va
When you deal with adding electronics to your car you are putting a strain on the oem electrical system..... usually a rule of thumb is that once you start talking over 1000 watts upgrades need to be made to your system( battery, alternator, caps)...... but what will happen if don't upgrade your amps can not get that power from your current battery and alternator and it will try to take it from other places like your headlights flickering and other strange stuff with cars electrical.... so when you say you have 2 1500 watt amps that is in perfect world with good electrical 14v, but in your situation during demands from you amps you may be sitting at 10 volts if don't upgrade possibly send your amps into protection mode(low voltage)
Dilutedpjn
Dilutedpjn
That makes perfect sense. Thanks for taking the time to hit me with some knowledge. Now I will take some time to research these upgrades.
