Maximus1
- Joined
- Mar 6, 2017
- Posts
- 241
- Reaction score
- 108
Ok, I have a 2004 LT 5.3L Flex fuel L59 engine. I currently have the cast #862 heads. I just purchased a rebuilt set of cast#799 heads. I'm sending them off to have them CNC ported and milled .030 to match the 862 compression ratio or maybe even .040 to up the compression ratio. Will I still be able to use the same pushrods or will I need to purchase shorter pushrods. I think the stock pushrods are 7.4" in length. Theoretically if I mill the heads .040 then my pushrod length needs to be 7.36 in length? Is this correct? Is that much really going to matter on a hydraulic lifter and if so can I buy a pushrod with that exact length.
