What a coincidence Felix! I had the same exact issue a couple of weeks ago.
I got in, started the Tahoe up and...... nothing. I turned it off, and then back on thinking it would reset, but still nothing. The radio was dead, I had no chimes or turn signal noise, the park assist was out, no rear camera, no lock pick, and the onstar system was out (red light on rear view mirror).
So, to make a long story short - I opened up the hood and located the "Audio System" fuse. I believe it's fuse #41 on the Tahoe located in the "under the hood" fuse block. I pulled it out, and put it back in and viola! It worked. Everything was back on and working properly. I don't really know what happened, or how pulling the fuse and putting in back in "fixed" the issue, but it hasn't happened since then (knock on wood).
Whether the issue you are having is the same or not, I cannot verify. However, based on what you have posted, I would venture to say they are. I would guess that if pulling the fuse doesn't work, you could very well have a blown fuse.
I hope that helps! The fuse number for your vehicle, and the location should be stated in the manual. Let me know how you make out
