Help identify these parts
laprodigy001
Had some work done a few days ago and i was just checking around the engine bay and i noticed a few items where broke and missing. But i cant figure out what they are called.here is pics
jerryjoe28
That Guy
cabot AR
2nd pick looks to be you PCV valve hose. should connect to a little piece that gos in your valve cover
first pic Im pretty sure is always open
laprodigy001
laprodigy001
On the pic with my hand in it. there is a blue and red plug. Where that is plugged into there is a piece broken.is that where it goes.
laprodigy001
laprodigy001
Here are 2 more pics. The part i cant identify is the part with the red n blue plug.
DallasTahoe
Here how they should look hooked up
DallasTahoe
The first pic you showed has a vacuum line that goes across the top of the intake and attaches to another little canister looking thing that is at the bottom of the AC dryer
SunlitComet
OBS Jedi-Do Good
unknown at this time.
first is the vacuum line attachment to the water valve solenoid and the second one under the intake hose is for the evap system. they do not actually connect together.
jerryjoe28
That Guy
cabot AR
no idea why I never got the alert that you posted the better pics. but looks like Sunlit got you taken care of!
laprodigy001
laprodigy001
The first pic i posted with the missing hose by the pcv valve. does the missing hose go to the evap solenoid?
Phoenix2k9
