Just noticed this the other day. Learned the hard way and almost got rear-ended at night. Sure enough, the brake lights are not coming on unless the pedal is basically slammed to the floor. Some quick research suggests that it is more than likely the pedal switch? Does it need to be replaced or can it be adjusted on this particular truck? Any help is greatly appreciated as I do not want to drive it until fixed. Thanks!
