It sounds like the blend door actuator. I've never replaced mine but you can do a search on it. Edit: I'm not sure if it's the blend door or a different actuator that controls that part of the heating.Ever find out what was happening?
My 01 Tahoe is doing the same thing. Rear heat works great, but no heat in the front.
Actually, if I have the temp turned all the way to the hottest setting, but do not have the fan turned on, you can feel a little bit of heat coming from the vents, but as soon as I turn the fan on, it is like there is only a small amount of heat to be had. After a second, the air gets cold...
This^^^blend door. Fan works right? Lower the temp a little and see if that works or slowly go from cold to warm, stop before completely on hot and see where that gets youIt sounds like the blend door actuator. I've never replaced mine but you can do a search on it. Edit: I'm not sure if it's the blend door or a different actuator that controls that part of the heating.
