Getting rid of squeaks and rattles
OilfieldTrash78
I picked up a ‘16 Denali with 29k miles. It has quite a few sqeaks in the interior when going over bumps. I can take it to the dealer, but don’t really want to sit there and point out every squeak. Is there a way to fix some of these myself?
Thanks
dbbd1
If it squeaks going over bumps, I would start with silicone lube and go over bushings (shocks, sway bar links, etc) and such.
DWTahoe
Colorado
I think the back seats in general make a lot of noise when going over bumps and stuff. I think it's because of all the automatic latches and power fold systems. Let us know if you have any luck getting things quiet, I'd be interested in what you figure out. Thanks.
O
OilfieldTrash78
Will do. I bought some felt tape to try and help with some of the sqeaks and stuff in the dash.
salanizi
My '15 Denali also does the same,
I was once with the dealership test driver driving the truck around (after fixing the shifting drivers seat via TSB), and every time we hit a bump we would hear a squeak from the trunk; the dealership guy told me that is the trunk door latch which needs adjustment and lubrication.
I just ignored it....
Tahoe14
Central Fl
When I got my early build 15 I had several squeaks around the center console. Sprayed them with silicone spray, wiped off the access and never heard them again.
ylwdogs
