Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
This is a 2015. They didn't last 23k? Another question that nobody can answer. Getting tired of these frequent visits to the dealership. I think they are actually the shocks that are leaking.
B
23 k and leaking??? That does not sound right?? It should still be under warranty?? Can you actually see that the shocks are leaking?? Is it an "Auto Ride" are they still doing that we have a 2004 (Denali.)
Same thing here mine started to leak around 15k i thought maybe i screwed it up while offroading but every one is having same issue mostly the front left side one goes bad and they dont even replace it under warranty if u r car is above 10 k
Anything can fail at anytime, but, yes, I'd be very disappointed at such a premature failure. And I'd also keep an eye on the replacements, if the same part number, to identify a similarly premature failure, in which case I'd strongly argue for replacement with a non-factory-original part.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
