Crcz71
Hey fellas need some input from you guys on a light issue. Walked outside this evening to see my fog lights were on but barely the vehicle not on and not running. They are led pods that I have wired with a factory pig tail so I didn't have to cut and splice the factory wiring. I installed them back in November of last year. I have had zero issues. When I looked to make sure my head light switch wasn't on and it wasn't. I noticed the indicator light for the fog lights was on. I started the Tahoe turned all the lights on then off and everything was fine except the indicator light. I checked to see of the fog lights were off and they were. Got back in pulled the switch out for the fogs and unplugged it. Got out and fogs are on but barely once again. I pulled the relay and the fuse out for them and they didn't go off. I unplugged the lights and moved it away from the house in case there's an issue and it catches on fire while we are asleep tonight. Get out start to walk away and the headlights come on flicker and go out. So I disconnected the battery. Is there an issue with the headlight switch since they have to be on for the fog lights to work? The only thing I have done recently is upgraded from a 130 amp alternator to a 145 due to audio system and I'm installing factory electric fans next weekend. Any help would be great before I start tearing things apart to find out what it is.
