BaMaDuDe87
Water pump - new
Thermostat - new (Didn't do the put in water trick to test it though. Came from stealership. Third one so far)
Fan clutch - new (actually off for the past few days too see if it seemed to make a difference. Nope.)
What am I missing? I'm thinking an overheating engine would be easier to diagnose at this point. "Burped" the system about 5 times now. Got a cooling system pressure tester coming, block tester to check for combustion leak and a compression tester. Guess drop another $35 for a new thermostat again and test it before putting it in this time? Can it really be hard to make and test thermostats before selling them?
Sent from my SM-N910V using Tapatalk
