scottbrew92
i know Energy Suspensions doesn't list a kit for our vehicles but I know people are running them and have been try to find out which part number is being used. Anyone who has done this would be a great help..!!!
It depends on how lifted or lowered you are. I could go look up the ones I used but I'm lowered 2" in the front on spindles. You want your swaybar parallel and that's why you need to measure.Yeah I’m just interested in the front kit....guess I’ll have to measure everything out. I was hoping someone had done it and had the part numbers.
With that much of a lift you definitely need longer ones than stock. Their catalog will guide you through it.Ok, I gotcha...I’m installing the 7.5in lift on my 07 Tahoe and the oem link bushings basically fell apart unbolting them and my 07 Yukon,or my sons I should say now, is lifted 3in.
and mysteriously lost one along the way and needs replacing. Appreciate the info...!!
Thanks for the info...would you know the diameter of the sway bar for the bushings?With that much of a lift you definitely need longer ones than stock. Their catalog will guide you through it.
Not for a stock one. I have DJM front and rear.Thanks for the info...would you know the diameter of the sway bar for the bushings?
