Electrical Problems
Therealcrazy8
Not sure if I have this in the wrong section, but I apologize if I do.
I have an '09 Tahoe LT and over the last few days I have been having some quirky electrical issues. There's times where the truck wont even start but if I keep trying or give it a few minutes it starts up fine. There are other times where I see the overhead lights pop on and think that it'll start and it doesn't, but the radio will come on and all of the dash stuff. Another time, when I was on the highway and put the cruise control on, it wouldn't stay on very long and then all of the sudden I could see the speed dropping down because cruise was turned off. That happened 3 times in about 5-10 minute period. Another incident I thought one of the back windows was down just a hair and so I pulled up on both window buttons on my door to close them and the radio went off, not sure if I had cruise on or not that time. On that note, there's been a few times where the radio just randomly turns off and back on.
None of this makes sense to me and only recently started. I disconnected my lights I installed under the hood to make sure that wasn't an issue, and the behavior continues. I have a cheap OBD II reader that I use just to read and delete codes and it didn't see any codes. I also had On-Star run a diagnostic and they didn't see anything either. Just for good measure, I had my battery and alternator tested, and both came back as being good. Has anyone else experienced this? Is there anything I can do to troubleshoot more than I have? Any help is much appreciated.
cmc76
i think you are going to have to start inspecting your grounds.
kbuskill
NE. FL.
The search button is your friend.... Lol
You need to replace your cables going to your battery.... Very common issue with these trucks.
T
Therealcrazy8
That's where I started. I must not have used the right keyword(s) because I wasn't able to find anything. Thank you for the help.:)
kbuskill
NE. FL.
Since your cables are most likely bad you should have your battery load tested and possibly replaced.
wbhidalgo17
