ok. I have a 2007 Tahoe. My drivers side turn signals will not work. Front, back or the dash light do not light up when you turn on the switch. however if you press the hazard button, everything works. also, if you lock or unlock the car with the key fob, the turn signal lights work. The only fuse i can seem to find is the left trn stop fuse in the fuse panel by the drivers side door. That fuse checks out fine. I have already replaced the turn signal, wiper switch and still no luck. Is there anything else besides the BCM that i can try. maybe a flasher module or a relay or other fuse that I am not aware of? any help is greatly appreciated.
