Drive shaft rubbing on cross member
Chevy*808*
image.jpg After adding the drop hanger . I notice I'm rubbing the drive shaft on the x member . Can I just remove the x member and run with out it ? Is there anyother way to fix the rubbing problems Lmk thanks
ccapehartusarmyINF.(ret)
Gilbert AZ
can you hear when it rubs ?
if its rubbing on the x member im afreaid its not a quick fix youve just uncovered a far bigger issue
either a motor mount is broke or its a bad u joint what ever the case maybe something in yer suspension or motor is being allowed to torque so much its rubbing and it shouldnt rub at all
kentf3
