Disk brake adjustment on 2002 GMC YUKON SLT
crabbman
GYPSUM,COLORADO
Hello did a search box help for this topic and came up with parking brake adjustment.
My daughters 2002 brake pedal goes to the floor board under semi- heavy braking.
I could do a re-do on all brake line bleeding and see what happens?
Some how check the Master Cylinder for something?
And some one here on the forums can tell me something else?
Just replaced all rotars and pads,including Parking brake about 3,000 miles ago.
Thank you.
01ssreda4
Master cylinder or air in the lines. Disc brakes dont have adjustments.
crabbman
crabbman
GYPSUM,COLORADO
Thank you Sir for the info. I will do a redo on bleeding all brake lines and then see where i am.
Good day.
SnowDrifter
Washington. The desert side not the Starbucks side
Provided the master cylinder is good: Bleed bleed and bleed some more. It'll take you 2 quarts of fluid at least. You'll proably have to do a couple ABS stops, then rebleed, then do it again. Air likes to get trapped in there and without access to a techII or other high end scan tool, that's your only option to get it out
crabbman
crabbman
GYPSUM,COLORADO
Than you SNOWDRIFTER. Didnt know that gmc yukon are a ----- to bleed. Oh well i will just turn on Pandora and live in the garage for awhile.
Thank you for the heads up. This is my daughters car i bought for her. Still a great s.u.v.
Good day.
afpj
If you have an assistant pumping the pedal to bleed the brakes, do NOT let them push pedal all the way to the floor. You's likely need a new master cylinder after that.
crabbman
crabbman
GYPSUM,COLORADO
Thank you AFPJ. I had mt daughter do the pumping last time. I believe that is my problem. There is a tool or some other method to bleed brakes Solo but forgot what that is?
Do you remember
rockola1971
Indiana (formerly IL)
ABS has trapped air in the lines/ABS manifold if you have cracked any lines open. You wont get it all out if you just do the traditional bleed. You have to activate the ABS so it will push the air past the solenoids in the ABS system.
crabbman
crabbman
GYPSUM,COLORADO
mitchievu
