Cooling System Overhaul
ge0rgin0
EL CHUCO, TX
My 05 Regency is reaching 119,*** miles. I noticed i'd have to top off the reservoir more often than usual so after a careful look i found a leak on top tank driver side radiator.
So i been thinking, to fix and clean it I'm lookin at around $90 at a local shop, new $105 lifetime
At Autozone around $200 but im gonna get them to price match so i can rack up points for the extra $20, hey that's a gallon of Antifreeze right there.
But while im at it was thinking of dropping in a new water Pump AC Delco $125 Lifetime and a good thermostat, what temp. Specific you all recommend?
I also noticed the timing cover gasket might need replacing too.
Thinking of doing all that and i wont have to worry about it for a long time
Other day, on my 96 Tahoe the squeaking from under the hood was driving me crazy, ended up dropping in new Alternator, idler & stabalizer pulley, ac bypass pulley and a new serpentine belt and wow!! Next up is removing the fan clutch and wiring up electric fans
Cbrpilot2
