Although I have never experienced this issue, I have heard about this and apparently it's fairly common and it's caused by a ground issue. You have a bad ground somewhere. Most people have said that there's a ground on the driver's side frame in the area under the driver's door. There's also a cluster of ground wires on the frame on the front driver's side frame rail in front of the radiator. Start by checking all those Ground wires and if you see ANY rust or corrosion, clean it and put it back together.
A bad ground will cause all sorts of headaches, like the cluster going dead or going haywire, door locks and windows and mirrors all acting up, and even the radio. Being that your cluster is dead, plus the mirror is acting up, I would check all the ground wires.
