Michigan
- Joined
- Sep 6, 2016
- Posts
- 258
- Reaction score
- 130
I have a 2004 Tahoe z71 with 164k on it. I bought it in December from California so the lines are not rusted.
I had front brake pads and rotors installed about a month ago.
Just the other day while driving on the freeway the check brake system message appeared ok the dash and with about 30 or so dings along with the abs and brake icon illuminating. I parked the truck and started it back up and the message and icons still appeared.
I pulled the negative cable off the batteryto reset it. Drive it for 2 days with no issue and then today when pulling up to my house after driving it 60 miles on the day the message with icons and dings happened again. I parked it and then when I got back in a couple hours later and started it up to leave there was nothing. It was back to normal.
Brake fluid is fine
Truck brakes fine and brakes feel very good. They don't pulsate and the pedal doesn't go to the floor.
Only thing I can think of is I had a wheelbearing done on the passenger side about a month ago at the same time I had brake and rotors done. Maybe they didn't plug the abs plug in correctly? It was a moog part but if this was the case it probably wouldn't take a month to show a symptom in guessing. Does the abs plug come disconnected easily?
Any ideas? Can any codes be pulled if the message and icons are not illuminated?
Is this usually serious or would I kind of know it?
+ QuoteReply
Brake fluid is fine
+ QuoteReply
