Cam wire and GMOS-04 Reverse Wire
treehan77
TYF Fiend
Crestview, FL
have searched many, many threads involving backup cameras to no avail. Has anyone actually used the reverse wire that is supposedly provided from the metro GMOS-04 harness itself? Everyone seems to get the wire from the a-pillar or reverse lights themselves for some reason. Does this wire work (05 Yukon w/Bose, no factory Nav).
Also, how did you guys actually route the camera wires into the back of the truck? Is there an opening already or what. Planning on either a license plate cam or one that goes between the hatch and bumper where I see most of you put it. But haven’t seen how you got the wire into the truck from there. Thanks.
jaywoo65
Cabot, AR
I tapped into the reverse light power wire right at the back of the truck. I guess the drawback is that the camera will only come on when the truck is in reverse and some people want to be able to turn it on in drive. Also, drilled a hole in the driver's side rear right near the light, ran the wires inside the truck and then sealed it with silicon.
treehan77
treehan77
TYF Fiend
Crestview, FL
Could you snap a quick picture of the wire entry point ?
treehan77
treehan77
TYF Fiend
Crestview, FL
To answer my own question- - yes. The GMOS4 has the reverse wire in the harness. Still don't understand why everybody on here tapped into reverse lights or the green wire in the pillar when its in the harness but whatever. The cam i installed had a RCA cable with a red lead attached to it. Reverse wire from the GMOS4 only goes to the head unit to switch to the cam when in reverse, the red lead gets attached to power so it is on when the radio is on and can be used anytime.
treehan77
treehan77
TYF Fiend
Crestview, FL
also, the wire needed for auto dim feature on the headunit is NOT included in the GM harness, so the GMOS-04 isn't conncted to anything. Tapped into the brown/ white wire from the a/c unit below the radio, works perfectly.
George ramos
