Brand/model suggestions on steering parts?
drowssap
Colorado
Hello all.....if this is in the wrong section I want to apologize in advance and kindly request it be moved!
I read comments pertaining to steering boxes, pitman arms and idler arms being better from AC Delco pro above moog for a number of reasons so I picked them up. But I want to replace everything else and am not finding solid info after a two hour search! I loaded up the cart with delco pro and stopped. Can you guys recommend brand and part number for the following:
Upper and lower control arms
center link, tie rods and tie rod ends
Front spindles for 4wd
Most the truck will see is a 2" lift up front so that is why I don't need cognitos but would like all parts to be of OEM or better quality.
Thank you very much for any and all input
MCAT069
Texas
I went with AC Delco professional when I did my front end refresh. It is pretty much personal preference - you will get some that live by Moog as well as some that swear by the $150 18 piece e bay kits.
Chubbs
I can't see what kind of truck you have but here is 2003 Yukon
Just renavigate to your spec M/Y at the top, should be all the same parts you see here.
Delco pro inner tre 45a1311
Delco pro outer tre 45a0785
https://www.rockauto.com/en/catalog/gmc,2003,yukon,5.3l+v8,1415551,steering,tie+rod+end,7428
Steering Link
https://www.rockauto.com/en/catalog/gmc,2003,yukon,5.3l+v8,1415551,steering,center+link,7276
Knuckles
Control arms
Delco pro upper: 45d1103
Delco pro lower: 45d3174, 45d3175
https://www.rockauto.com/en/catalog/gmc,2003,yukon,5.3l+v8,1415551,suspension,control+arm,10401
This is big money. Spend it like it ain't yours!
