Brake Pad Recommendation for Towing
Discussion in 'Engine & Drivetrain' started by Dan Acosta, May 14, 2018.
  1. Dan Acosta
    Dan Acosta Full Access Member
    86
    19
    Feb 26, 2017
    Name:
    Dan
    I have read a bunch of threads on brakes, but it can get a little confusing.
    To simplify, I dont want to do the NNBS upgrade at this time. Maybe in a few years.
    So for now I tow a travel trailer monthly. It stops OK, but I need to replace the pads, and was looking for a recommendation for a pad upgrade that might make a noticeable difference. No dust would be a bonus, but stopping is most important.
    That being said if there is a part that would make an additional improvement, I would consider. For example - SS lines. Do they really make a difference in stopping, or just a firmer pedal?
  2. drakon543
    drakon543 Full Access Member
    679
    78
    Feb 15, 2016
    Name:
    james
    i bought the power stop towing package brake kit for my Tahoe. i dont do that much towing myself but i did do a bit of towing shortly after i put them on. pretty light utility trailer loaded down with my sisters stuff from moving. i think there was a noticeable difference between stock and these. can't say it was a night and day difference but i did notice a difference. it was also enough of a difference the wife even noticed it.
  3. Dan Acosta
    86
    19
    Feb 26, 2017
    Name:
    Dan
    Was that the rotors & pads? or did you replace the calipers as well?
  4. Doubeleive
    Doubeleive Elite Member Supporting Member
    2,021
    1,100
    Name:
    anything premium ceramic will work better and last longer than standard pads
    swathdiver likes this.
  5. Scottydoggs
    Scottydoggs Full Access Member
    628
    428
    Dec 16, 2017
    NJ
    Name:
    Scott
    i went with R1 E line drilled and slotted rotors and scorched ceramic pads.
    just stock replacements. 200 for all 4 corners shipped. i have not towed with it yet, but they are night and day over the last set of crap i bought it with.
    a large trailer should have its own brakes, if they are working you should hardly know its back there.
  6. drakon543
    679
    78
    Feb 15, 2016
    Name:
    james
    i bought the premium kit with the calipers but the calipers aren't needed if yours are in good shape. i only bought the premium kit with calipers since i liked that they are powder coated. i also bought thier kit for 2 other cars also, my civic and a pontiac i used to have. my neighbor also has them on 2 of his vehicles now also.
  7. Dan Acosta
    86
    19
    Feb 26, 2017
    Name:
    Dan
    OK, I am considering the new rotors, was thinking only pads. I usually dont turn my rotors unless necessary. How do you guys do it? Do you turn everytime, or just when grooved?
  8. 4WDTRK
    4WDTRK sleeps in garage
    345
    49
    Mar 24, 2015
    Socal dreaming of Norcal
    Name:
    Roland
    Always best to replace or have turned.
  9. Doubeleive
    2,021
    1,100
    Name:
    I usually just replace mine with the pads, there cheap enough to just replace, or if there in warranty I will just exchange them the auto parts store usually doesn't question it
  10. ezstriper
    ezstriper Full Access Member
    101
    25
    Nov 2, 2010
    Name:
    Rob
    I have tried 3 different sets on my av, prostop ceramic. bendix severe duty w/rotors, and now delco police.ambulance. all helped a small amount, the delco are semi-met and squeal like a pig at times...
Share This Page
