Goosebumps
- Joined
- Aug 26, 2017
- Posts
- 5
- Reaction score
- 3
So guys i'm new here and i wanted to share my experince fixing a leaking hydrobooster hope you find it helpful
I'll post a video that was helpful to me fixing the issue plus I'll write my experince and answer your question regardin the fix
Btw this my first time working on the car fixing an issue after watching tons of youtube videos and reading.
After losing power steering fluid and refilling it for more than month i finally noticed that the leak was from the brake hydroboost assembly between the brake master cylinder and hydroboost assembly.
The only special tool needed for the fix is E12 torx socket 3/8" drive and 15mm deep socket 3/8" drive
Before starting deplet the pressure from the system but the car key on off position and press the pedal 5-10 times, disconnect the nigative battery connection.
Disconnet the master cylinder from hydroboost assembly 1 bolt on each side 15mm. Slide it back away from the booster.
You'll find 3 lines connected to the booster unit, you need 15 & 18mm wrench and pliers to remove a clamp from the low pressure hose.
Now moving under the dash driver side behind brake pedal you'll find 4 bolt connecting the booster unit to firewall using 15mm deep socket remove 4 bolts, after that remove the clip thats holding brake pedal switch and the rode arm from the booster unit.
Now you can remove the booster from the fire wall slide it back and up towards you, take it to the bench and start unbolting the torx e12 around, splited apart and change the piston seal you can buy it from amazon the link for the part will be posted below. Screw it back and reverse the previous instruction.
Repair Kit
GM 2771004x Hydro-Boost Repair Kit Seal Leak Repair Universal Kit Rubber Only https://www.amazon.com/dp/B01J2PD1NQ/ref=cm_sw_r_cp_api_CuBOzb83K974M
Hope you find it helpful
Repair Kit
