afpj
- Joined
- Sep 16, 2009
- Posts
- 780
- Reaction score
- 311
Hi all,
02 Yukon 4x4 176k miles. Tried to install Russell braided brake hose kit, but ran into an issue with bleeding the lines. On rear caliper, when I open the bleed screw, more fluid leakd out the base of the screw than through the hole. Is that normal? It's a frickin mess with that. Took out the screw all the way and the hole on the bottom was plugged with junk, cleaned it, but it still leaks more from the bleed screw base than through the hole. Anyone encounter this issue before?
BTW, the Russell hoses have a smooth coating on them, so no exposed braids, and the fronts do not follow OEM routing path FYI.
