Battery replacement
Discussion in 'Engine & Drivetrain' started by Texas70, Feb 7, 2018.
  1. Texas70
    Texas70 Member
    39
    17
    May 11, 2017
    Name:
    Scott
    Found this video recently and thought I'd share
    https://www.youtube.com/watch?v=n2zJg4HnwH8
    What a PITA just to change a battery out! Turns out I didn't need a new battery after all. Upon further investigation I discovered that the engine drive belt was off and found several of these also,
    I'm assuming he knocked the belt off on his way out of the engine bay upon remote start.
    iamdub, Miami-Dade and swathdiver like this.
  2. DWTahoe
    DWTahoe Member
    82
    27
    Mar 4, 2016
    Colorado
    Name:
    DW
    I did discover you can fit one of the batteries from Costco, I believe it is an Interstate bat without removing the air box. It was tight removing the original but it can be done. The new battery was a little smaller and went in without removing everything.
  3. jeffbco
    jeffbco Full Access Member
    213
    48
    Oct 7, 2009
    Name:
    Jeff
    This is a better video showing how to do it without removing the air box, coolant reservoir, etc.
  4. DWTahoe
    DWTahoe Member
    82
    27
    Mar 4, 2016
    Colorado
    Name:
    DW
    I wasn't sure if there was an issue laying a battery on it's side? Anybody know for sure if that's a problem, even for a short bit just to get it in place?
  5. dbbd1
    dbbd1 Full Access Member
    397
    139
    May 12, 2017
    Name:
    David
    If it's sealed (or caps on snugly- do they even make them this way any more?) it should be fine, especially just for a few moments to get it out of there.
  6. Texas70
    Texas70 Member
    39
    17
    May 11, 2017
    Name:
    Scott
    Thanks for the tip! Will have to remember this next time.
  7. jeffbco
    213
    48
    Oct 7, 2009
    Name:
    Jeff
    If the new battery was a little smaller it probably was DIN size H6. The H7/94R size is the OEM size. H6 is same width and height as H7 but about 1.5 inches shorter than the H7 (and fewer CCA's too). I'd stick with the OEM size.
  8. Texas70
    Texas70 Member
    39
    17
    May 11, 2017
    Name:
    Scott
  9. Texas70
    Texas70 Member
    39
    17
    May 11, 2017
    Name:
    Scott
    I'm planning on it. I had a new battery in waiting that dealership sent home with salesman I bought truck from as we live in the same town. The one they sent though was an ac delco 48HPG which didn't match the original. Turned out I didn't need it & was wrong one so I returned it.
  10. DWTahoe
    DWTahoe Member
    82
    27
    Mar 4, 2016
    Colorado
    Name:
    DW
    That probably sounds about right on the battery size and I do remember thinking it was a little bit less on the CCA's, but not much. However, that was the one they had listed and I don't have any extra accessories on the Tahoe. Plus it was like $110 instead of some of the ridiculous prices I've seen posted. We will see how it goes.
Share This Page
