Anyone running 305/70 16's or 33x12.5?
EastTXYukon
Longview, TX
Just curious to see some pics of an OBS with 305/70 16's or 33x12.5.
I've finally made up my mind, and have decided to just add a 2" rear block and crank up the TB's a little. It'll do till I can afford a real 6" suspension lift.
Only thing I can't decide on is tire size. I'm gonna go with some AR Crater
16x8 rims with 4.5" backspacing. I am trying to decide between a 285/75 16 or if I want the tire to stick out wider with a 305/70 16.
Both tires are bascially the same height but the 305's are about an inch wider than the 285's
Any pics or opinions are appreciated
Arctic-Rodz
RGV Texas
well depends on what fits on your ride, or how much side wall you want.
I went with 17x8" Eagle 140's on 295/70R17 Nitto Trail Grappler M/T (33.4")
I did have to cut the edge of the bumper cause it was scraping a lot. Gonna need a real 4" lift to give me the clearance i need. But it'll work for now
h0tr0d
Brenham, Tx.
Get the 285's or break out the Sawzall....your choice. The 285's are a perfect fit IMO, and if you don't have factory flares, they'll be sticking way out. They stick out just the right amount with my flares.
bowtiefreak
No Quarter
Near Philly
I did with no crank. It rubbed on big bumps but never turning. I'll see if I can find a picture, but I do not recall taken any of it.
edit: with 4.5" BS on the wheels you will rub a lot with out a little lift. When I put my new wheels on before the lift they had 4.5" BS and I had to run a 265 to clear with no issues
foreverfalcon40
Will 285's rub on a stock or lowered application? I'm going to need 4 new tires for the Duece Dubs :(
I run a wider and fatter tire in the rear compared to the front. Front some times like to jerk cuz the tire is a little to skinny I think its a 255. I would love to go wider with no turning issues.
ff40
992door
Greenville, NC
I am running 285's on mine wheels are 17x9 and i had to do a little cutting to get them to fit and my torsion bars are about maxed out and they still rub on bumps if i am turning.
