Air Conditioner quits blowing from vents
cactusjak
I have a 08 Suburban, the ac works fine for a while , then the air quits coming out of the dash vents, it doesn't get hot, or anything, it just quits coming out of the dash vents. I shut the AC off for about 4 mins, then you can feel the air coming out of the dash vents again, turn on the AC again and its good for about 20 mins the it happens again. I just don't want to start throwing parts at it. anyone else have this problem? Thanks in advance.
gpracer1
Phoenix
Does this happen with the fan on high or when using on a lower blower setting.
Next time it happens turn only the AC button off, not the main power (to keep the blower going) and see if it starts blowing after a few minutes. If you smell moist air and it blows hard again then your evaporator is freezing up.
Cbrpilot2
