Here's how I did mine.
I can't credit for all of this, there is a YT video on this somewhere.
Get the Spark plug socket and add 2 adapter extensions..... This make the PERFECT length setup.
Spark plug socket, 3/8 to 1/2, 1/2 to 3/8
Then I removed the heater hose bracket. The video had said to undo the dipstick bolt. I did NOT. This is with the bracket removed.
Remove the oil stick and tuck the heater hoses behind the tube.
This gives you PLENTY of room to work.
Pull the boot off the coil first, then twist off the wire at the plug.
Slide your socket contraption onto the plug first then snap in your 3/8 ratchet.
If there is a thread on this already please delete or merge.
Thank you.
Thank you.
