Having the same issue. I followed the GM book to the letter as far as removing valve lash in the order specified then turning the rocker arm nut 1 full turn. When I put it all together I had 0 compression in all cylinders except 6. After removing the valve covers, I noticed that the valve adjustment was too tight and luckily did not bend any rods, or destroy any valves!
What am I doing wrong??? Should I check compression after adjusting each cylinder before putting it back together? Or, am I looking at the wrong issue as far as 0 compression? I replaced the head gaskets, did a valve job along with a timing chain and a water pump.
The last time I had rebuilt an engine was 20 years ago! This is the sixth time I've done this and never had an issue until now. So, What is my brain Fart??
