05Zsvntyfun
- Joined
- Mar 16, 2017
- Posts
- 88
- Reaction score
- 41
Perks of converting my Tahoe to a 4L80 and how difficult would it be?
A more reliable transmission. I blew my stock trans on the stock engine. Once the engine is modified it's a ticking time bomb. These trucks should have come with the 4l80s. Different yoke on driveshaft and modifying crossmember some wiring harness mods, computer tuning and flex plate depending on the converter you use..Perks of converting my Tahoe to a 4L80 and how difficult would it be?
Sent from my SAMSUNG-SM-T377A using Tapatalk
I'm in the middle of the swap doing it myself. Have about $3k in it but I already had a tune with black bear so it didn't cost to do the segment swap. I got a good deal on the trans, but I'm running all stainless steel lines with AN fittings and a $,$$$ triple disc converter and I'm using the conversion harness from speartech so not your cheapest options. AWD is going to be a different monster with the transfer case. I'm 2wd so I can't offer any input on that. I'm sure you can do it for a lot less, but I didn't wanna use that heavy factory converter, didnt want to splice anything or reuse my old lines and firmer shifting than factory.Did you do this swap then? I am thinking of doing it myself, because I plan on towing a lot more with my Yukon, but mine is an AWD Denali, so not sure if the swap is even an option with that transfer case. If you did do it, about how much should I figure on spending?
there is a build called charlie murphy on performancetrucks.net. He has a 4l80 and awd and his thread should be a good resource for you. https://www.performancetrucks.net/f...hevy-silverado-project-charlie-murphy-489579/
It's a good long read I am 4 pages in. This guy is amazingthere is a build called charlie murphy on performancetrucks.net. He has a 4l80 and awd and his thread should be a good resource for you. https://www.performancetrucks.net/f...hevy-silverado-project-charlie-murphy-489579/
