265/70/18?
dak244
i apologize if this has been asked and debated but I tried to search and couldn't find anything definitely (although I am admittedly on my mobile phone which is more difficult to navigate!).
Anyway, as the title says, will a 265/70/18 fit on the Hybrid without issues?
Thanks.
Big Mama
Virginia
What year is it? Is it 2wd or 4wd? What size are the stock tires? If it's a new to you truck look on the inside driver's side door post for the original size. What's on it now? Has the height been modified? Is there a reason you want so much sidewall?
D
dak244
It would be a 2009 4WD. Plane stock. From what I understand the stock tire size is 265/65/18 -- so it would only be going up a size, but that's practically an inch on the same width. May be some other combo that works better? (i.e. 275/65/18?)
Big Mama
Virginia
I would say an inch should work easily. My 305/40/22 are the same height as your stock tires but 2 inches wider. My front is lowered 2 inches and I don't have any clearance problems. Hope that helps. Tiresize.com has a nice converter.
2DoeProjectHoe
