2015 Tahoe Brake Squeak? Edit: Wheel Bearing
Bighurk
Hello all, hopefully I posted this in the right place. Recently I started hearing my brakes squeak and I thought it was the brake pads being thin so I changed them but now they are still squeaking. I have ruled it out to just the front right but while the truck is moving forward the squeak is extremely loud and unbearable. When I hit the brakes that’s when it starts to stop. I have checked it again and again but cannot seem to figure it out.
Has anyone have had similar issues or can let me know what can be the potential problem?
Thanks!
dbbd1
Did you have the rotors re-surfaced or did you replace them? Follow the mfg's break-in procedure? Use brake grease?
Bighurk
Bighurk
I only replaced the pads. But this problem surface before changing them and previously when I brought it to the dealership they had checked the brake pads and we knew they were a little low.
And yes I did use brake grease.
dbbd1
How many miles are on the rig?
dbbd1
To me, it sounds like the brake wear indicator (the squealer). They squeal, when the brakes are worn down (high-pitched), until you put the brakes on. Did the tone change slightly from the old pads to the new or remain the same? It may be that when you put the new pads on, you put them on wrong (squealer on the top vs on the bottom) or bent it. It should not be touching the rotor (at least not until the pads wear down a lot). Take the tires off and spin the rotors, see where the noise is coming from.
as stated above also check that the thin metal retainer/clip is not bent so it is touching the rotor, mine was doing that a while back, freaking annoying, it would squeak unless you had your foot on the brake basically.
Bighurk
Bighurk
I have taken the wheel off and spin the rotor but still can’t seem to hear anything but I will try again. Thanks!
Bighurk
Bighurk
This sounds like me right now, so I will check the clips and see if they are bent. Hopefully that is the issue
cardude2000
Does it continue once depressed or is it only when you move the pedal?
pikelk98
